LT1 and vortecs?
Old Mar 12, 2003 | 11:40 AM
Jackal8069's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
LT1 and vortecs?
Has anyone ever tried puting an LT1 intake manifold on vortec heads? I was thinking that the port design on the manifold "should" be the same as the vortecs.
Old Mar 13, 2003 | 10:26 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It won't happen, read my FAQ.
Old Mar 14, 2003 | 08:51 AM
Jackal8069's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
Wow, alot of info there! So I take it the LT4 intakes are compatable with the high port heads (fast burn/vortec). Wouldn't the intake from caprices and impalla SS's be the same as these? I think I recall them using the modified ports.
Old Mar 14, 2003 | 08:56 PM
Engine: 4.0L
Originally posted by Jackal8069
........Wouldn't the intake from caprices and impalla SS's be the same as these? I think I recall them using the modified ports.
You might be right. I am assuming you're talking about the L99 4.3 V-8. It is a little funky and I've seen pictures of them upside down looking at the ports and they look just like the LT4 ports. Again, this is only through pictures, no measuring.
Old Mar 14, 2003 | 11:32 PM
Jackal8069's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
I'd like to see this actually. For everything it's worth, it'd be a cheap injection manifold to run on a set of nice heads. I've generally seen them not run too high, and I bet it'd be cheaper than getting the SD intake and then parting a TPI together.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
monte87cortez
Sep 26, 2015 08:10 PM
L0tuS
Sep 4, 2015 11:16 PM
