Rubber fuel lines safe?
Old Mar 25, 2003 | 07:53 PM
rumpilstiltskin's Avatar
I have an 86 lb9. Are rubber fuel lines a safe replacement for my stock rusted-through metal ones? Can they handle the pressure put out from the fuel pump?
Old Mar 25, 2003 | 10:50 PM
Iroc n roll's Avatar
Yes. but make sure they're made for that application to handle the psi and use the right connectors, (ie heater hose and hose clamps won't cut it).
Old Mar 25, 2003 | 11:13 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i agree...you will be fine. just get the right lines...they will be labeled something like "high pressure fuel line" or something along those lines.
also, make very sure that you use the correct clamps or whatever. if you have to flare the end of the current line you plan on connecting the rubber line to, then do it. if you can pull them apart...then find a better way to clamp them.
-brian
Old Mar 25, 2003 | 11:16 PM
so flaring the end of the metal line and then putting a hose clamp on it would be suffiecient?
Old Mar 26, 2003 | 12:20 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
that is what i did for a while before i put my stainless lines on. i didnt have any problems with it.
-brian
Old Mar 26, 2003 | 10:09 AM
Notice how he says "before I put my SS lines on". We didn't say it wouldn't work. But is it safe......no. You can risk it if you are in a pinch but I certainly wouldn't drive around like that much. A leaky coolant hose is annoying, a leaky fuel line could prove diasterous.
Old Mar 26, 2003 | 10:31 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
The flare would help alot. I'd keep a fire extinguisher in the car, though.
Stainless lines (brake and fuel) are available through in-line tube and other suppliers.
Best-
S-D
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
