Injector gurus... enter please.
Old Mar 25, 2003 | 08:03 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Could anyone tell me what injectors I have here by the number? I would appreciate it.
Jason
8287 17122683 The rochester sign is on it too if that helps narrow it down.
Old Mar 25, 2003 | 08:55 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
well no guru here just a guy that uses google. They look like multec 1 injectors rated at 24lb/hr with 12 ohm resistance saturated. The table doesn't indicate what fuel pressure they operate at to achieve 24lb/hr though.....
Old Mar 25, 2003 | 09:02 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I tried google.....? Oh well, thanks though...
By the way, what are Multec 1 ?
Old Mar 25, 2003 | 09:17 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
When searching google just type in the 17122683. Multec1 injectors are GM's first attempt at being better than Bosch. By the way I think the Multec1 made by Rochester are the same injectors that Rich from CruzinPerformance uses as skipping stones. I could be wrong tho.....
Old Mar 29, 2003 | 01:43 AM
metalgod's Avatar
90 - 92 s/d cars 305's tpi all had 19 lbs injectors @12.5 ohms and the 350's had 21.6 lbs injectors @12.5 ohms
92-Formula
Dec 12, 2015 10:34 PM
Jonesyfxr
Sep 26, 2015 02:08 AM
ULTM8Z
Sep 16, 2015 09:15 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
