What is this?
Old Mar 27, 2003 | 10:57 PM
fbird89frmula35's Avatar
What is this?
Not sure what this is?
But thought it could be important because it was coming off the throttle body
Old Mar 27, 2003 | 11:01 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Its a breather hose that should go to a grommit on your passenger valve cover.
Old Mar 28, 2003 | 12:02 AM
chevyboy07 91's Avatar
LOLOLOL......that looks like someone plugged the hose with a spark plug!?!?!?!? Is this a trick question LMFAO
anyway, that is indeed a breather hose as stated above. You're prolly spraying oil around out of that hole in the valve cover.
Anyway, you can leave that hose plugged and put a breather on the valve cover if u want
