Vacuum
Old Mar 28, 2003 | 09:11 PM
BFDPerformance's Avatar
Vacuum
ok guys...im trying something radical here so please dont tell me it cant be done.....im wondering on a TPI what absoutely has to have engine vacuum....i know the power brakes...but other than that anything? otherwise can i just plug all the other vacuum ports.....thanks
Old Mar 29, 2003 | 01:27 AM
metalgod's Avatar
i run crane #100082 226 deg,.470 lift,106 lobe sep,advanced to 101 deg. 6 inches of vacuum in neutral in my 305 @ 550 rpms. Now they say there is no way this cam will run in TPI car cause of lobe seperation. THIS IS B/S!!! they were right in a way though, the car would not idle at all below 2000 rpm,i went and bought a stock 89 vette chip for the 3.07 performance ratio auto. they also said that wouldnt work in there either. But the car idled and never died, started good and ran like a raped ape. never surged. The cam is now in a 427 ci(i think)400---.040 over??? and it has much more vacuum, but both run fine with the vette chip
Old Mar 29, 2003 | 09:43 AM
3gc's Avatar
3gc
Car: Z28
The fuel pressure regulator needs vaccum, hvac controls (or else you will only get air out of the defrost vents), the egr valve and solenoid unless you wanted to get rid of egr, the power brake booster, there's also two connections from the charcoal canister to the throttle body, one for vaccum, the other for fuel vapor. You could get rid of your curise servo if you wanted. Hope this helps.
Old Mar 29, 2003 | 12:51 PM
metalgod's Avatar
mine worked great @ 6 inches of vacuum. no problems at all.
Old Mar 30, 2003 | 01:13 AM
ok first how do i get rid of the egr and will it rob me power....second im runing 114 lobe sep...i have "eliminated" the charcoal caniser...and the cruise cont is "eliminated"...as well as the heat/ac and blower motor....this i going to be a street strip car so i wont really need air....so the only places i absoutely need vacuum is the power brakes and the fuel press reg right?
Old Mar 30, 2003 | 03:48 AM
metalgod's Avatar
if you disconnect the fuel pressure regulator, the computer will map the block learns more acurately with a larger cam shaft. but as far as disconecting things for more vacuum, it wont help to plug things up. Disconnecting the egr valve doesnt rob you of power. you may get a bit more throttle response??? that is the first thing i disconect when i buy a car lol. if you get a vacuum resevuar from an early 80's camaro, you can run a larger cam and the vents will still work. i would run vacuum to the brakes and fuel regulator with that cam r u looking for more power? i have a few tricks if you wanna email me. ill get back to you.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
