No start
Old Mar 28, 2003 | 10:30 PM
3gc's Avatar
3gc
Car: Z28
No start
I'm finishing up my 350 TPI swap. Here's the specs on the motor. New short block, l31 poted vortec heads, lt4 hot cam, roller rockers, sdpc tpi baseplate, slp runners (with 9th injector hole plugged), 24# used LT1 injectors, mildly ported plenum, hooker headers, All new ignition components except the distributor, cap, rotor, msd coil, msd plug wires, bosh platinum plugs, msd 6al ignition box.
I'm getting a nice spark and i checked timing and it should be right on yet the engine keeps cranking over. I used a noid light and there are injector pulses but the light is very dim, basically just the filiment lights up. I checked all the ground connections and even used an ohm meter and each ground wire on the connectors for the computer has about 1 ohm of resistance to the nut for the seat. So all the grounds are good. So i figured it was a computer problem so i bought a new computer and still it does the exact same thing. The prom in it is for an 86 305 TPI auto, but it should be able to start using that. I have to send the memcal away and get the new custom bin burned on it.
Tomorrow i plan on lifting the fuel rail and seeing if the injectors are firing fuel. The engine should be flooded but i hardly even smell any fuel on the plugs.
Also fuel pressure drasticallly drops off when i stop cranking. When I turn the key to run it gets to about 15 psi and when i crank it over it jumps to 40 or so but when i stop cranking, in about 20 seconds almost all the pressure is gone.
Any ideas as to what could be causing my problem? My goal is to get it running by wednesday, my 18th birthday.
Old Mar 29, 2003 | 10:57 PM
clippjr8's Avatar
is the prom for the 86 tpi not for the cold start injector? you need to program the prom to get the car to start with the cold start injector pluged if the original car had one.
Old Mar 30, 2003 | 10:56 PM
3gc's Avatar
3gc
Car: Z28
The 86 still has the cold start programed into it. I'm sending that away tomorrow to get a new bin burnt onto it though. Hopefully that'll change it.
Old Mar 30, 2003 | 11:37 PM
rezinn's Avatar
Does fuel pressure drop rapidly after the pump is primed? 15psi is not adequate. It should be something like 45psi when primed.
I'd be wary that those injectors are leaking a lot or grounded. Maybe try your stock injectors.
Old Mar 31, 2003 | 02:18 AM
xanax's Avatar
my fuel pressure does the same thing. i had the same exact kind of problem when i went to stealth ram. my coil decided to play tricks on me, it wouldnt start the car with the plugs in the chamber, i guess compression kept them from firing. i put a new coil on and it fired up first try. the injector pulses dont make the test light very bright on my car either.
Old Mar 31, 2003 | 01:41 PM
3gc's Avatar
3gc
Car: Z28
The coil is a brand new msd coil. I bought a new fuel pump yesterday, i'm gonna start putting it in tomorrow. Hopefully that'll be it.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
