View Poll Results: Cutting back plugs...yea or nay?
Yes, it's totally safe & easy...so you goofed somewhere ROC-Z.
16.67%
No. Bad unless your driving a race car. Easiest way to ruin a new set of plugs on the street.
0%
Noobies are dumb. Go buy a Honda.
83.33%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
worst case scenario?..I cut my electrode back to far & their installed!
Old Apr 7, 2003 | 10:59 PM
ROC-Z's Avatar
I have an AccelŽ SuperCoil (47K volts) & 8mm wires.
I took a set of R43TS AC-Delco plugs, and cut the ground electrode back to the edge of the center electrode. Left the original gapping alone @ .035.
I installed them in my car, and my idle went from semi-smooth (with my fouled Autolites) to rough and shaking with my cut back AC-Delcos. I figured this would happen, and should of left well enough alone.
I had to drive the car about 15 miles today...it runs, but rough obviously. I can't get around to putting in new plugs till later this week.
My question is:
Can I cause any serious engine damage, by just driving it a couple miles? What's the worst that can happen from running the engine?
Thanks for the help-
Old Apr 7, 2003 | 11:15 PM
ZZ405's Avatar
Car: 89 IROC
Engine: ZZ4
ground electrodes
I doubt cutting back the electrodes on you spark plugs caused your car to run rough. You may have a loose/bad plug wire or you may have cracked a plug in the process of installation.
I have cut back 3 sets of plugs in the past couple years for my IROC and never had any problems.
Old Apr 7, 2003 | 11:25 PM
ROC-Z's Avatar
In some areas on the wires I could tell where it had gotten hot, but didn't burn through...on two plugs wires, I pulled the boot & connector right off the wire. I crimped them back on though.
Do you think I should buy some nice MSD wires and looms, before I pull the plugs out?
Old Apr 7, 2003 | 11:33 PM
ZZ405's Avatar
Car: 89 IROC
Engine: ZZ4
If you're pulling the boots and ends off the wires I wouldn't think twice about replacing them. I would think that is what is causing your problem.
Old Apr 7, 2003 | 11:38 PM
ROC-Z's Avatar
Ok, thanks for your advice.
I'll look at those low resistence MSD wires...depending on how much the crimp tool is, I may buy the "cut to fit" kit.
Do you, or anyone else know if right-angle boots fit with stock exhaust manifolds? (In case I need to buy pre-fabbed MSD wires)
Old Apr 8, 2003 | 03:26 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The MSD Cut to fit wires come with the crimp tool! I finished mine last week and theyre AWSOME wires.
Summit P/N: MSD-31229
90* boots, HEI, Red, Cut to fit.
$69.95
Old Apr 8, 2003 | 09:37 PM
ROC-Z's Avatar
$69.95
Cool! Do you run headers? I don't, so I'm not sure if 90* boots will work with my stock manifolds...what do you think since we're both running the same engine? Or does anyone have some input here?
Old Apr 9, 2003 | 08:24 PM
ROC-Z's Avatar
OK, so three people think I'm dumb....but how many know if right angle boots will work with stock manifolds? Or do I specifically need straight boots with stock manifolds?
Old Apr 12, 2003 | 06:57 PM
ROC-Z's Avatar
::::::::::::::::::::UPDATE:::::::::::::::::::::::::
I changed the old plug wires with a factory replacement set of 8mm wires. It made a noticable difference in park @ idle and higher RPMs....but still did not fix the issue.
So, I've come to the conclusion that I did cut the electrodes back too far.
I've got the answer to my other question, since I changed my own plug wires for the first time & no-one else would say sh*t & help me out.......right-angle boots will work on all cylinders with stock exhaust manifold. Had I known this earlier, I would have bought a set of MSD spiro-coreŽ wires instead of a factory set.
Later, when I take the plugs out I'll post a picture of them in this thread.
Old Apr 13, 2003 | 01:35 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Dude...I voted that you should buy a Honda...
Don't cut the electrodes...simply install them and the rest of the tune-up and be on your merry way...
HTH,
Old Apr 13, 2003 | 12:59 PM
ROC-Z's Avatar
HTH,
Hehe...I thought more people would have actually voted me to get a Honda & become the R!cer poster boy
Yeah, as far as the electrodes are concerned- it looks like I learned the hard way. I was going for more gas mileage, not necessarily more HP though. At $1.70+ a gal. I'll take every little bit of gas mileage I can! Since I know modding for HP has already been covered here, I'm now wanting to look into: Modding for gas mileage....and see what turns up.
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
