Easy Stealth Q
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Easy Stealth Q
One last question, (i have mixed answers from the search), is the stealth drilled for the 87and later TPI heads?
very simple, will it bolt to my oem heads,(see sig)
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Are you talking about the Stealth ram? If so, some were drilled and some were not. If you order now, the newest lowers have been drilled for both.
The holes will accomodate the bolt angle, but the face angle won't...Weiand sells a wedge thingy that gives the bolt a flat surface to torque against. Check w/ Holley tech support (Holley owns Weiand).
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I got my spacers from Summit for $50.
Im not sure what the part number was, but I typed 'bolt spacers' in their product search on their site and it brought up the part. The bolts that come with the spacers will not work, they arent the correct size, so be prepared to buy some different bolts as well.
Im not sure what the part number was, but I typed 'bolt spacers' in their product search on their site and it brought up the part. The bolts that come with the spacers will not work, they arent the correct size, so be prepared to buy some different bolts as well. Thread Starter
Transmission: 4l80e
so what you guys are saying is Yes and no, if they are drilled for the angle ok but if not, i will need some wedge washer deals to make the head of the bolt sit flush.... am i getting this right
If you use the HSR on '87+ angled heads you will need the wedges. You won't have to modify the HSR, just add the wedges.
Transmission: A4
I have this same problem. I put my HSR in today and found out I need some angled wedges. I did put the bolts in anyway to torgue the intake down to make sure it was lined up. What will happen if I dont get those wedges. Will the holes leak oil of something?
Gunner242
Dec 25, 2015 04:49 PM
3.8TransAM
Oct 1, 2015 07:47 PM
