quick head Q
Old Apr 9, 2003 | 12:06 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
quick head Q
88 305 heads are the same as 92 350 heads correct? Both are TPI.
Old Apr 9, 2003 | 12:19 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
No their not the same. 350 L98 heads have 64 cc chambers and 1.94 (I believe) valves. The 305 lb9 heads have 58c chambers and smaller valves(dont remember the sizes).
Old Apr 9, 2003 | 12:28 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Crap.
If I throw the LB9 heads on a 350 what kind of problems will I have? Will I have at least the same butt power as an LB9 with 305 heads?
One more option - If I throw 350 heads, casting 14102193 1.94"/1.5" on a 305 what problems will I have?
Old Apr 9, 2003 | 12:35 PM
Only problem with 305 heads on the 350 is that itll choke it. As for the 350 heads on the 305, you should be ok with the 1.94 valves... any biffer and you would run into clearance issues.
Old Apr 9, 2003 | 12:41 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Choke it noticeably to the point where I'm gonna be disappointed?
Old Apr 9, 2003 | 01:05 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
get a little port work done on them and youll be fine. the 58cc combustion chamber (same as vette aluminum heads) is going to up your compression ratio and will give you more power. If you were to go down to your local machine shop they shoule be able to port em out for you if you want, but if you dont I doubt it will cost you much horsepower. I dont think it will choke it bad at all.
Old Apr 9, 2003 | 01:28 PM
iroc22's Avatar
It won't choke the 350 that bad. The 305 heads use 1.84/1.50 valves while the 350 head uses 1.94/1.50 valves. Not a huge difference. The intake runner volume is slightly more on the 350 heads but the 305 heads can be helped with a quick port and polish. Factory castings can usually be improved on quite a bit.
Old Apr 9, 2003 | 02:19 PM
Without a good amount of port work, youll be disapointed with ANY stock casting.
Old Apr 18, 2003 | 02:08 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I'm back to toying with this idea.
Can I fit 1.94 valves in 305 heads? I'm looking to put in a 350 bored 40 over with flat top pistons. I'm shooting for a compression ratio between 10 and 11:1.
Old Apr 18, 2003 | 04:00 PM
iroc22's Avatar
Yes.
mike_c
Aug 27, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
happyhapka
Aug 15, 2015 04:42 PM
