AFPR setting on LB9
Old Apr 15, 2003 | 01:49 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
AFPR setting on LB9
u guys with LB9s peanut cam or L98 cam what do u guys run ur AFPRs at and what did u get for a power increase at the track and SOTP?? i was thinkin about getting one but i dont know if its worth it.
Old Apr 16, 2003 | 12:19 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
it can vary from car to car... some like more than others... when i adjusted mine from stock to 49 psi the SOTP feel was there definatley... play w/ it at the track and see what happens...
Old Apr 16, 2003 | 02:15 PM
bigals87z28's Avatar
Car: Check The Sig
slp and chris.. what kind of afpr did you guys get? and are you happy with them? any problems? I heard that 305's respond to afprs better then 350's? I might need one after i do all the mods i have planned... i dont know.. i also need an aldl scanner
Old Apr 16, 2003 | 02:16 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
to be perfectly honest... i don' t know what mine is... i got it used from a buddy of mine... he just gave it to me when he swapped to a miniram setup...
Old Apr 17, 2003 | 12:26 PM
90form305tpi's Avatar
Car: 1990 Firebird Formula 305
Engine: 305tpi w/145,000 on the clock
I installed a Crane AFPR about a month ago. I would definately recommend it for anyone with a 305 tpi. The SOTP of course was there however, taking it to the track and doing a little "test and tuning" is the best way to find an optimum setting. Mine landed at 49psi as well.
I think the Crane model is great. It is easy to adjust w/an 8mm wrench so you don't have to take off the plenum to play w/it. Without a doubt a good buy.
gta90
Sep 15, 2015 04:00 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
happyhapka
Aug 15, 2015 04:42 PM
kyleb24
Aug 15, 2015 08:24 AM
