Injectors staying open?
Old Apr 16, 2003 | 11:42 AM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
I need major help fellows,The injectors are not closing at all.I have verified this with a noid light.Naturally it is running rich,and I have changed out the ecm,memcal/prom but has the same problem open injectors the moment you turn the key to start/on.
I am about to check the ground wire from the computer that feeds
the injector for its neg./ground source.Are there any other suggestions??? any would be greatly appreciated.thanks
Old Apr 16, 2003 | 02:04 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I remember reading a problem a while back where a guy's car was doing the same thing... He went through months of troubleshooting to find out that he tightened the fuel rail down to tight, and was making ground contact with a part of the intake..
I don't remember how he resolved it, but someone else might be able to chime in with more information...
Old Apr 16, 2003 | 05:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I had 2 injector that were mechanically stuck open (failed plunger) sp? Anyways, those 2 injectors caused me to blow my stock motor. I didnt find that out until I put them in my new motor and had gas pouring out the driverside header as I was trying to crank it up for the first time. THe only thing that sloved it was new injectors. How many miles do you have on those injectors?
Mike (1bad91Z)
Old Apr 16, 2003 | 06:47 PM
RBMZ28's Avatar
About a year.....they are Accel 32lb. injectors.I am running the
miniram so the fuel rail is not an issue for it.thanks for the reply
any more responses!!!!!any!!!
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Apr 30, 2019 12:14 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
