86 or 88 TPI system
Old Apr 16, 2003 | 04:31 PM
cj7's Avatar
cj7
86 or 88 TPI system
Short Story, I aquired a 305 TPI motor that I'm putting into my jeep. I'm doing a complete rebuild. I'm in the process of installing fuel rail/plenum/ etc. Issue? I have an 88 block with 79 heads that i pulled out of an 86 camaro. How can I tell what year TPI system I have. It did have the BOSCH injectors and has the ninth injector/cold start going to the plenum/intake manifold not the fuel rail? I think. Any help would be great so I can Identify replacement parts
Cj7
Old Apr 16, 2003 | 10:34 PM
rockind78's Avatar
Re: 86 or 88 TPI system
Cj7
Ninth injector runs from the fuel rail(s) on all '85-'88 TPI. The above information would seem to suggest that you probably have a TPI setup (assuming it all came from the same car) from an '85 or '86. If you want more clues, take a peek at the ECM and look at the numbers. The '85 ECM was a unique year, and '86-'89 ran the same ECM. I don't remember the #'s on the '85 ECM, but the '86-'89 ECM's were #1227165 for F-bodies. The Y-bodies may have been a bit different. Hope this helps.
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
