Code 42, will setting timing trip this code?
Old Apr 19, 2003 | 04:16 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
When you unhook the spark advance will this set of a code 42? I think I remember this, but you cannt search for code 42 becuase 42 isn't longer than three letters. This is the only code I get after the cam swap and engine over hual. I checked this to see if I could find the answer to my lower idle issues. I think the ECm is learning the new cam like it did last time.
Old Apr 19, 2003 | 05:05 PM
xanax's Avatar
yep
Old Apr 19, 2003 | 09:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, as soon as you disconnect the timing bypass connector, code 42 will set. Clear the codes, and if it does not come back, thats all it was.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
