Rockers ticking more than usual
Old Apr 21, 2003 | 07:47 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I've adjusted them about a dozen times, but it still seems like they're making too much noise. Sounds like every single rocker is ticking. I suppose it could be the injectors, but I'd like to narow it down. The heads have been milled, would this throw the geometry off just enough to where the stock pushrods are a hair too long? They're aluminum L98 heads with comp 987 springs and stock rockers. I don't want to overtighten them and burn up the valves!
Old Apr 22, 2003 | 03:56 PM
tpi_roc's Avatar
Did you adjust hot or cold static or dynamic?
I recommend adjusting them with the engine warm and running, thats just my opinion and has never done me wrong where as cold or static can always leave one or two a little loose or tight. Also sometimes it can be nearly impossible to tell the difference by ear between valve lash and a leaky header/manifold, if your adjustments haven't made ANY difference, maybe you should suspect a leak. Injectors as well make noise, but I can hear the audiable difference between that and lash, although it is close.
good luck
Old Apr 22, 2003 | 05:07 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
yea, might want to check your header gaskets, mine tick real bad. I'm gonna replace the gaskets tomorrow
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
