intake sensors HSR
Old Apr 24, 2003 | 10:18 PM
The00night's Avatar
intake sensors HSR
Ok got the stealth ram and im getting the sensors put in on it. in the manual it calles it a manifold air temp sensor. well none of the auto part stors have one in the data base. Can some body give me a parts number to look for.
Old Apr 25, 2003 | 10:59 AM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Try the dealer, they should have the part and # for you. Or do a search, on here somewhere I can't remember what section it was in, but someone also has a part# book for with all the part # for camaro and firebirds. But the dealer should have what your looking for.
Old Apr 25, 2003 | 11:29 AM
S10Wildside's Avatar
What happened to the MAT sensor in your plenum? Or didn't you have a TPI car?
The TPI manifold air temp (MAT) sensor is brass and located underneath the plenum.
I have one that I pulled from my running TPI system. I am no longer using it because I'm running with the LT1 intake. If you want it I'll send it to you for $10 shipped (Priority Mail). If you're interested email me at mike@s10wildside.com and we'll work something out.
Old Apr 25, 2003 | 11:10 PM
The00night's Avatar
i figured out the deal the intake manifold sensor in the stealth Ram book is old. their was a change in manufacturing they use the same sensor that the coolent does its just a diffrent plug now. in case anybody else runes into this problem but thanks for yalls help
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
ASE doc
Aug 25, 2015 09:14 AM
355tpipickup
Aug 22, 2015 06:06 PM
