Quick timing mark question
Old Apr 29, 2003 | 01:16 PM
Thirdgen86TA's Avatar
Does anyone know how the timing marks go on my car?
86 Trans am 305 TPI
Is the center of the biggest valley 6 degrees TDC and then every point goes by 2? I am a little unclear because mine is rusted and I can't see.
THanks
Old Apr 29, 2003 | 05:54 PM
anyone know?
Old Apr 29, 2003 | 10:20 PM
88TAJeff's Avatar
Car: 88 T/A
The center of the biggest valley is 0 deg and it goes to a maximum of 12 deg at the top.
Old Apr 29, 2003 | 10:34 PM
Is the next point 1 then the next valley 2 and so on? Or does it only count by the valleys?
Old Apr 30, 2003 | 08:33 AM
88TAJeff's Avatar
Car: 88 T/A
IIRC, they count by 2, both on peaks and valleys. Clean it up with some steel wool and you'll see the marks. Or if you know the max is 12, you could interpolate and divide it up.
Old Apr 30, 2003 | 08:57 AM
88TAJeff's Avatar
Car: 88 T/A
OK it was bugging me so I just checked mine. The first valley after the biggest one - towards the top - is 6 deg. They are spaced kinda funny, but after 6 deg, they go by 2's
Old Jun 23, 2003 | 10:56 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
so the biggest one is 0 degrees. and towards the two other notches is advanced so the smaller notch right next to big is 6 degrees and the small one next to it is 8?
midge54
Dec 27, 2019 04:14 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
