Can't get car to idle high
Old Apr 29, 2003 | 11:02 PM
aaronkark's Avatar
Recently my car broke down.....they said that it needed new spark plug wires.......done.......now I can't get the car to idle correctly.....I even try and set the timing high but it just won't idle high.....any suggestions..By the way I am aware of how to set the timing.
Old Apr 30, 2003 | 12:32 AM
aaronkark's Avatar
by the way my car is an 88 formula 305 tpi auto
Old Apr 30, 2003 | 02:51 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
No clue man, I am having the exact opposite, I am idling way too high, currently I am idling at 1500 rpms. Only thing I could possibly suggest to you is to check your Idle Air Control Valve and Throttle Position Sensor. This seems to be the trouble with mine. Just spent $40 on a new IAC and it still idles high, suppose it was my TPS gonna see if I can change that out tomorrow, either way I needed the new IAC, when I pulled off the old one is was black as hell from carbon, good luck to you on your problem.
Old Apr 30, 2003 | 08:19 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
What do you consider low idle? A V-8 in one of these cars will idle anywhere between 500-750 to 1000rpms depending on your configuration.
I have heard of stable and smooth idle at 450rpms.
My car for example is a 1987 Trans-AM 305TPI A4. My car idles at 1000RPMs until warmed up and then idles at 750RPMs.
Old Apr 30, 2003 | 08:59 AM
aaronkark's Avatar
Well a month ago the car broke down and all they did was adjust the throttle posistion sensor. When it broke down again I checked the sensor and adjusted it to .58 and the highest you should go is .61 Does this sound ok to anyone who is an expert? Basically what I am saying is that the car isn't as fast as it once was before this all started happening about a month ago. It idles real low and stalls every so often. What are the signs of a bad TPS-Thottle posistion sensor? Basically I have payed for 2 $75 diagnostic fees and I don't want to have to pay again. The car runs but not like it should. Thanks for any help given.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
