vaccume leak.
Subscribe
May 5, 2003 | 03:49 PM
how can you tell if you have a vaccume leak ( like leaking runners etc ), how will the car act?
Reply 0
May 7, 2003 | 01:09 PM
well it depends where the leak is to what u will experience. do u think u are having vaccum leaks? if so, explain ur symptoms
Reply 0
May 7, 2003 | 01:33 PM
Usually a vacuum leak will cause an abnormally high idle. Check all your vacuum hoses and replace any cracked or brittle ones. If you think you have a leak around the runner or something spray around that area with carb cleaner, if you hear the engine stumble then you have a vacuum leak. Be careful when doing this and do it when you first start the engineand it is not hot so you don't have a fire.
Reply 0
Subscribe
