How do I Look for Injectors in the Bone Yard? Help
Old May 6, 2003 | 09:38 PM
KustomIroc's Avatar
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Hi Guys
I remember reading an article in Car Craft some time back that
explained what vehicles to look for that had interchangeable injectors with my 86 TPI Iroc-Z. I want to upgrade to larger
injectors. What do I look for in terms of vehicles and or part numbers to match up a set of 24 lb or larger injectors for my car?
Thanks,
Jamie
Old May 7, 2003 | 12:59 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
i dunno, buying new injectors might be worth the money, if u put enough money into ur car to need bigger injectors, u might as well just buy new ones
Old May 7, 2003 | 01:14 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I don't think you will have much luck looking for fuel injectors in a bone yard. Just bite the bullet and buy new ones, better reliabilty.
Old May 7, 2003 | 02:35 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Junkyard injectors will be a pretty hit or miss proposition. A set of used LT1 or LS1 injectors off boards or ebay will be at least as cheap as what a yard would cost, and at least then they probably came off an engine that wasn't sitting dead for months/years. No matter what sending them out for profesional clean/flow matching is still a good idea, and IMO an absolute necessity if you don't know who you bought them from. Otherwise you could end up with a completely fubared engine from a bad injector
pjsparts
Oct 29, 2025 06:39 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
