fuel pressure problems...please help!
Old May 6, 2003 | 06:42 PM
wild 87-Z's Avatar
I have an 87 Z-28, 305 TPI. fuel pump wasn't working so I replaced it. it ran ok for a couple hours then the pump sounded bad so I replaced it again with an ac delco pump. the new pump sounds ok but it wouldn't stay running and my fuel pressure was only up to 15 lbs. I changed the fuel pump relay, fuel pressure regulator and fuel filter. after changing the regulator a while ago the pressure goes up to 10 lbs. while the pump energizes then drops to zero when the pump stops energizing. I checked for any fuel leaks and can't find any. is there something I overlooked? what's going on with my car? any help will be greatly appreciated. thanks
Old May 6, 2003 | 08:20 PM
BOTTLEDZ28's Avatar
Transmission: A4
is the pump getting a full 12 volts of power. check that. if you get under your car and look up above the rearend you will see a plug with 2 wires going into it. the plug is fastened to the body of the car. just unplug it and put a multimeter to it. check to see if it drops as you turn the key foward
Old May 9, 2003 | 12:30 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
1st make sure the guy at the parts house didn't give you a carb fuel pump. 2nd with a pressure gauge connected, take a pair of pliars and clamp the fuel return hose. Pressure should jump up immediately. 3rd get a Walbro fuel pump
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
