Stealthram without AFPR?
Old May 8, 2003 | 04:50 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I got my order from summit today, and I got F'ed over as usual..
No AFPR in my 534-186 kit.. Everything to hook up the afpr, just no actual AFPR..
So, after getting the runaround by their customer service, it looks like it will be at LEAST 2 weeks until they *find* one to send me.
Is there a way to make the 534-186 rails work without the AFPR in it?
I saw I can use the 90* end on the back of the rail (where you would normally plug it..) But, that doesnt solve the issue where the AFPR should hook up to it, in the smooth hole that looks like a 9th injector.
Any ideas?
Old May 8, 2003 | 05:05 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I was reading that a grand national FPR will work..
$25 from autozone for one.. Nonadjustable I assume.
What fuel pressure do they run at?
Old May 8, 2003 | 07:02 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I think are going to have to make a block off plate, or tap the hole and put a plug in it. Shoulda ordered from Thunder Racing...
Not trying to rub it in or anything, I have been *** raped by summit a number of times...
Old May 8, 2003 | 10:34 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Thunder was back ordered until June 30th.
Old May 8, 2003 | 10:38 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
how you regulating pressure without AFPR? Can't just dead head it.
Old May 9, 2003 | 08:43 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The GN FPR is supposed to be adjustable, at least the Delco one is.
Old May 9, 2003 | 03:23 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Checked out autozones AFPR for the 87 turbo regal.. Non adjustable.
It also didnt have the rubber oring/grommet that looks like it will be needed..
Where do i get one of those?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
