400 cam
Old May 12, 2003 | 11:27 PM
Chvelle_Guy's Avatar
Car: 1972 Chevelle
Engine: 406
Transmission: th-350
400 cam
Hi, im in the process of building a 400sb for my chevelle, and was wondering what the best cam would be for me to run with tpi. I will probly in the future, about 3-4 years, switch to a stealth ram. but right now im just using a basically stock tpi that i have ported the plenum on and siamesed the base.
What cam would you recomend for a 400? Id like it to atleast be good to 5500, so it will work decent in the future, but right now it needs to pull good to about 4800-5000rpm.
Thanks alot
Chris
Old May 13, 2003 | 02:41 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Sounds like what I have may be of interest to you...check my sig.
Although I know that it is a mild cam for my combo, I also have a stock-type bottom end with cast pistons and a 5600 or so redline...
HTH,
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
