To AFPR or Not To AFPR
Old May 13, 2003 | 11:40 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
should i get an AFPR. i installed the LT1 cam and on the snap on scanner my BLMS are up a bit meaning the cam leaned me out a bit. im not dangerously lean or anything, actually doin pretty good. but i was wonderin that my WOT AF isnt optimal, would it be a good idea to get an AFPR and **** with the pressure a bit? im running 97.63mph at the track right now. any ideas if id get anything out of it? i figured if i got one and played with it i might pick up .5mph and crack 98.
Old May 14, 2003 | 12:58 AM
BTS88IROC's Avatar
What mods do you have? If your car is mostly stock it won't help that much. Most stock cars usually run better with a little bit lower fuel pressure than factory.
Old May 14, 2003 | 02:35 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Get one
Old May 14, 2003 | 11:47 PM
MinionII's Avatar
Would the adaptive feature of the EEC not correct the A/F ratio if you alter it with feul pressure changes? It has been my understanding that the 02 sensor feedback is used to write correction to the feul tables, rendering feul pressure changes pointless after a quick drive. Unless, of course, your FP is out of the range of the adaptive feature to correct for?
Old May 15, 2003 | 12:14 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
At WOT the O2 sensor readings are no longer looked at.
It shouldn't affect his day to day driveabilty for the reasons you mentioned though.
Old May 15, 2003 | 12:47 AM
MinionII's Avatar
I'm sorry for my ignorance...I'm kinda basing my questions on my Ford EEC. In my case, the load table(90%) used for WOT is updated by the 02 sensor feedback, but not while at WOT. The 02 sensors are ignored at WOT. But, while the car is at 90% load, but not with the gas pinned, the 02 sensor data is used against this table.
geuss I should venture into the electronics forum..
Old May 16, 2003 | 11:40 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
yeah i definitly need fuel! im going to buy all new intake gaskets before i purchase an AFPR just to insure i dont have any vaccum leaks but. tonight at the track i ran a 98.12 mph with my stock MAF unit. my friend traded MAFs with me, his is a descreend stock unit. i ran the car and to my surprise the thing pulled like a raped ape even with a 2.3 60ft i did a 14.2 @ 99.76 then my next run i did a 2.4 60ft with a 14.3 @ 100.2mph run. i was amazed. i guess this means i need fuel? i could definitly smell the exhaust being a lot richer.
my mods are:
LT1 Cam
Ported Plenum
Centerforce Dual Friction
Poly Tranny Mount
Poly Torque Arm Mount
3.27 9 Bolt Rear
Modified Air Box
K&N Filters
Dynomax Headers
Dynomax Cat Back Exhaust
Cat Delete
Throttle Body Coolant Bypass
IAT Sensor Relocated
Emissions Delete
HVAC Delete
12* Base Timing
No Rear Seats, Spare Tire, Jack
Toyo Proxes FZ4s
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
