Old style SLP runners
Old May 15, 2003 | 09:31 PM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
Just wondering how many out there are running the old style SLP runners- the ones with one pair on each side that's fully siamesed...
I'm just looking for any feedback, good or bad, and any comparisons to stock or other aftermarket, including the later style SLPs.
I just put a set on my car (not running yet- long story) and am just wondering what gains I might expect on a 90 350 TPI. I matched the plenum (siamesed) and did the TB inlet, and also matched the runners, and blended the base on the sets where it's one runner all the way down. I also ditched the air pump and A/C , so I'm sure I'll think it's better...
FYI- the car has stock exhaust manifolds, big SLP Y-pipe, Flowmaster cat-back, and a cold air intake... Also, the EPROM is burned by me (which I'm sure I'll have to change all kinds of stuff now )
Anyone ever have problems with engines due to the varying runner length? Power balance issues?
Thanks for any info!
Old May 16, 2003 | 05:13 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
well i siamesed all four runners on my slp.
Old May 16, 2003 | 05:14 PM
mrr23's Avatar
Engine: 360 HSR
left the bottom alone because i didn't siamese the intake this trip
Old May 16, 2003 | 05:15 PM
mrr23's Avatar
Engine: 360 HSR
and the dyno result. granted i swapped from the lt1 cam and 1.6 rockers to zz4 cam and 1.5 rockers nad form stock runners and siamesed base to slp siamesed runners and edelbrock base.
Old May 17, 2003 | 08:20 PM
SCCAjunkie's Avatar
Car: 84 Z28
Just curious,
How did you go down that far into the runners? I have some ideas (I do a lot of porting work) but I'm not sure how others have done it...
Did anyone have to clearance the driver's side set of runners for the rearmost fuel injector? Or the rail? It was LOTS of fun to get together... I even managed to break the SLP tool (ball ended hex key), but luckily, it was while tightening the last bolt
Maybe I'll just make my own damn runners...:lala:
Old May 18, 2003 | 08:15 PM
mrr23's Avatar
Engine: 360 HSR
i have a bit that's about 6" long. worked it from both sides. no i didn't clearance for the rear injector.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
