tpi swap to LO3 block
Old May 18, 2003 | 12:18 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
i am planning a tpi swap to my LO3 block. since they have different heads, what kind of power increase if any should i expect. i was hoping for about 20 hp over the tbi.
what kind of power band would i be looking at (guestimate)
for those who have done this swap, how is the driveability compared to tbi?
thanks for any opinions, info, stats, etc.
mike
Old May 18, 2003 | 09:05 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Swap
17 HP and 70 TQ and the driveability will amaze you. Well worth the time and $$.
Old May 19, 2003 | 10:23 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
thanks, that sounds like quite a difference.
btw, how much of the wiring will i need. i know i'll need the ecm and the wiring under the hood, but there is another box behind my dash...? do i need that as well. and how about the wiring to the gauges etc.
thanks for any help
Old May 20, 2003 | 10:04 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
It's worth it just for the torque alone. You will be able to do burnouts now
Old May 20, 2003 | 11:52 PM
25THRSS's Avatar
Kinda weird how dyno don got 17 hp and 70 tq from the swap, I assume without changing anything else and 91rs5speed got only 9 hp and 39 tq from the same thing and that was also with underdrive pulleys, airfoil, aluminum driveshaft, and cold air intake to go along with it. You will also notice how the tpi setup dropped off before the tbi did. Makes you wonder if tpi is actually better than tbi?
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
