Headlight not popping up
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Hey Guys...just wondering if anybody has experienced or has any ideas about it. Sometimes when I start the car (at night) my lights are on but don't pop up. All I have to do to fix this is turn the car off and start it again. Does anybody know what might be causing this. It doesn't happen very often but I want to fix it because something will probably happen at the m ost inopertune time!
Darrell
1991 GTA
Darrell
1991 GTA
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Theres a relay for the headlight popup motors. Check the relay. Theres a post about it in the electronics section.
On my '88 GTA there is no relays and I believe yours is the same (GM service manual coincides). Next time it happens (lights don't pop up) pop the hood then THUMP your headlight module just above the master cylinder and see if they suddenly pop up. Mine did this also so I reseated all the connections into the module and that helped. Now, every once in a while, one headlight doesn't come up so I plan on replacing the headlight module. Pat
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Thanks I will try that. Sorry for posting in the wrong section I had a couple of message windows open and I guess I wasn't paying attention.
Darrell
1991 GTA
Darrell
1991 GTA
