Help.. Holey AFPR
Old May 26, 2003 | 01:47 PM
DreamState21x's Avatar
Help.. Holey AFPR
I just put my car back together and I installed a Holley Adjustable fuel pressure regulator. The one with the big *** on top.. Now that everything is back together he plenum is sitting on the *** and I can't turn it.. I thought these were supposed to have enough clearence.. Car cranks and then shuts off 2 seconds later so I figure it's not adjusted right... Did I not turn the *** down enough times before intalling the plenum or what.. Please help...
Old May 26, 2003 | 05:34 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
very possible you don't have enough fuel pressure. maybe under 20 psi when they injectors quit working. on mine it clears. on the guy i bought it from, we had to clearance his plenum to get it to fit.
Old May 26, 2003 | 08:04 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Its pretty common to have to notch the plenum a bit to give the adjustment screw clearance. I had to with my AFPR. Mine is not Holley though.
Old May 26, 2003 | 08:58 PM
thanks
Thanks everyone I went ahead and took off the plenum and notched it, works fine...
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
