Question on Vortec heads and Miniram
Old May 26, 2003 | 09:26 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
As most of you know, The Gm 350 HO Crate has Vortec heads on them and from what I read TPIS makes the miniram to install on them. Just a couple of questions......1) How hard is it to take off existing TPI (w/ Vortec Manifold $400 ) and install the miniram??? 2) Since I have the Vortec manifold already...WOuld it be better for me to port out plenum, buy some TPIS runners and add a 52mm TB????? 3) If I do go with the mini, Can I just buy the intake and plenum and run my existing other accessories??? example: Fastchip, 21 lbs injectors, TPI fuel rails etc etc etc
Thanks Guys
I am going to do something......just trying to figure out which route is better. MONEY IS NO OBJECT....but ease of install IS!!! (being it is my daily driver)
Later
Old May 27, 2003 | 05:54 PM
Bump
Old May 31, 2003 | 10:22 PM
BLOWN85/TA's Avatar
If you did NOT port the TPI Vortec intake or stock TPI plenum you should have that done. The Vortec manifold I got was damn rough and the ports need work. I would add runners and forget about the throttle body, it's not worth anything IMHO on your setup. It seems to me that you like bolt on stuff so this should keep you going stronger. If you want the Miniram you should learn PROM tuning before you switch it out, cause it's going to be a tuning pain.
Old Jun 1, 2003 | 01:45 AM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
TPIS does make the miniram for vortec heads...I believe they call it the Miniram III...I would definately recommend it, just make sure you don't leave it at that...plan to do mods that will compliment the Miniram.
Old Jun 1, 2003 | 09:27 AM
Z91Z's Avatar
Any times on your combo 89Z ? THANKS
Old Jun 1, 2003 | 09:56 AM
Dragroc's Avatar
I haven't taken my car to the track in oh i'd say about 2 years now. Best I got out of it then is a 13.7 @ 103, but since then I have done everything in my sig and then some. I just got done installing a 6 speed a couple of months ago. I figure the way it sits right now, I should be able to bolt on some drag radials and run 12.8's all day long, it runs really really strong.
Old Jun 1, 2003 | 02:10 PM
Z91Z's Avatar
THANKS
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
