What # fuel injectors came with TPI?
Old May 27, 2003 | 01:32 PM
82-T/A [Work]'s Avatar
I recently purchased a set of 19lb Accel Fuel injectors for my built up 3.1 v6/60. I had thought I'd be putting out about 200hp, but as it would turn out, I'm putting out more in the range of 170hp. So, as it would seem, I'm stuck with a set of brand new 19lb Accel Fuel injectors (8 of them).
There are TWO TPI cars a Formula 350, and an 80s Iroc-Z in the local junkyard (U-PULL-IT). Are the injectors in there 19lb or 17lb injectors?
Also, if anyone would like to trade a set of VERY low mileage 17lb injectors, I'd be willing to do an even trade for my brand new 19lb Accel Fuel injectors (or I'll sell them outright for $150 bucks).
Thanks,
Old May 27, 2003 | 01:58 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
a search would provide you with all the info you need, but since this is easy, I'll answer it anyway.
305s came with 19lb injectors. All L98s came with 22lb injectors except the 85 L98 Vette, which used 24lb injectors and a lower fuel pressure.
Old May 27, 2003 | 02:00 PM
Damn... I had no idea they were all that high!!
Oh well, I can probably keep these injectors for my 81 TransAm if I ever decide to go with some sort of TPI setup in the future.
Thanks!
bryan623
Mar 22, 2021 06:43 PM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
Sanjay
Aug 12, 2015 03:41 PM
