MAP sensor
Old May 28, 2003 | 08:58 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
MAP sensor
is there a map sensor on a TPI. if so where is it located pictures would be awesome. i think this might be the cause of my rough idle if there is even one on my car. sorry im not the best with TPI yet.
Old May 29, 2003 | 06:05 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MAP sensor
The '85 TPI will have a MAF, no MAP.
Your LO3 will have a MAP. Look on the cowl edge at the firewall, pass side. Will be a small black box sorta jutting out. Three wires and a vacuum line.
RBob.
Old May 31, 2003 | 11:17 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The MAP on the L03 is mounted in the recess in the right rear area of the plenum almost covering up the fuel pressure test fitting on the fuel rail.
Old Jun 2, 2003 | 01:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Isn't the L03 a TBI?
RBob.
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
