diagnostic help
Old May 31, 2003 | 10:17 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
diagnostic help
well, my tpi conversion is nearly done on my 82 trans am, so far have added it, edelbrock tes headers eliminated the muffler with 2 1/2 inch tailpipes only, which by the way the car sounds absolutely awsome for a stock LG-4, however I'm having a problem my check engine light is now on constantly, but first let me say wiring is not the problem since it is a complete harness out of a running 87 trans am, and the fuel pump is new, let me describe symtoms that car is encountering,
1 idles at around 800rpm (nuetral) after warm
2 whenever I open the throttle fast it wants to die
3 fires first turn of the key cold or hot
4 how do I flash the check engine light, please tell me eactely what wires to jump (from top to bottom right to left ect.)
4 is there a link here that give ecm codes.
got a bad felling Im going to see a code for the mass airflow sensor ( ............ kaaaaaaching $$$$$$$$$
will post some pictures of it when its all finished
Old Jun 1, 2003 | 09:26 AM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
....check the tech section on the front page, it has all the codes listed there as well as what terminals to jump(A&B). Keep reading the whole tech section, not just on code extraction part, it will help you out quite a bit.
Old Jun 1, 2003 | 11:51 AM
Jproz1167's Avatar
ok I'm getting a code 33, which Ive been reading about for the last hour so that one is not a problem, however I'm also getting code 36 ...... one other thing I failed to mention, I know I have a burned out fusible link at the starter since I have no battery power at the fusebox, could this be causing my trouble by chance ?
Old Jun 1, 2003 | 02:06 PM
Jproz1167's Avatar
ok so maybe code 33 is a bigger problem than I thought, upon closer looking I found the relay wires were sort of bare, so I replaced the relays and plug ends with weatherpack relays, however still no power to my blue wire at the maf, red wire gets power though while jumping PIN G on the alcl, no something interesting the red & the blue wires were spliced at sometime right at the mass airflow sensors plug, does this blue wire originate from the ECM itself ? or from the burn off relay, I switched ECM's by the way, that didn't do any better at all, so what do you all think the wire is shorted out somewhere going to the ECM its self ? oh and yes the relays are getting power and all
Old Jun 2, 2003 | 05:49 PM
Jproz1167's Avatar
new update
code 33 goes away if I cover my air filter up with a towel, I also need to add that I made my own intake air track and stuck a air cleaner on the end of the mass airflow sensor, with this what do you guys think bad mass airflow sensor ?
specialized
Jun 18, 2022 09:26 AM
GTAman
Mar 15, 2019 11:40 AM
mddaniel
Sep 8, 2015 05:16 PM
bowtie1983ss
Dec 4, 2001 12:18 AM
87ColdAirIroc-Z
Nov 9, 2001 04:31 PM
