Fuel Line Size Needed
Old Jun 2, 2003 | 06:09 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
I'm converting from a Carb to TPI and I'm wondering what size fuel lines I have to use. Also, do I have to run new lines all the way to the pump or can i use the stock steel lines that run along the driveshaft tunnel? I'm going to be running a Holley in-line pump with 3/8" NPT fittings, will the fuel lines for TPI fit onto that size fitting? Thanks.
Old Jun 2, 2003 | 06:32 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
pauldaniel
I did a tpi conversion on my 82 4 barrel trans am, it's truly easier to get fuel lines from a fuel injected V-6 f-body or fuel injected V-8 f-body there all the same, they run up the left side of the frame rails and are pretty simple to swap out. I used fuel lines from approx. a 87 camaro v-6 and they are 3/8 inlet and 5/16 return which is all you need
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
knight72
Aug 10, 2015 09:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
