Starts and then dies...
Old Jun 2, 2003 | 05:21 PM
BADBOWTIESS's Avatar
I just put my 87 350 tpi together but it only runs for about 2-3 seconds then dies. The timing is right i took off valve cover to make sure.
NEW harness, maf, distibuter, afpr. I have 42psi fuel and stays there through cranking ,pressure, good spark, injector pulse , car will fire and run only if the ninth injector is plugged in if i unplug the ninth injector it wont fire . i can smell gas but no go .
Also tps is at .57 ,computer also tested in other car
Old Jun 2, 2003 | 05:37 PM
tpi_roc's Avatar
How did you check timing by taking off the valve cover?
Old Jun 2, 2003 | 05:54 PM
both valves closed on compression stoke Isnt this correct?
Old Jun 2, 2003 | 05:56 PM
tpi_roc's Avatar
both valves closed MAKES a compression stroke
Old Jun 3, 2003 | 02:04 AM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
does it take a while for it to catch and start or does it just start? i have the same prob(i gave up and sent it to a mechanic to do it, i just dont have the tools to get it right) but he told me my timing was way off and my MAF was shot, just cause it is new doesnt mean nothing, i found that out the hard way, but timing and MAF i am going with, or maybe a bad TPS or IAC, lots of places to start
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
