My car is not gettin fuel???
Old Jun 3, 2003 | 05:13 PM
Trandizzle's Avatar
Car: 1990 Trans Am
Engine: TPI 305
Transmission: 700 r4
I have a '90 TA 305 TPI, a couple of days ago it started actin up on me. The car starts, but dies soon after, acts like it isn't getting any fuel. I have to keep it revved between 3-4 K RPMs just to keep it running. What might be the cause of this? Is it something simple like a clogged fuel line? Or maybe a sensor? I thought it may be that my catalytic converter may be clogged. Any Ideas or thoughts?
Old Jun 3, 2003 | 10:05 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Well, has it been getting worse on you? Did this just happen out of no where? Does the fuel pump prime when you first turn the key on? If you keep it revved up at 3-4k, how does it act?
Try setting the TPS and the IAC first. I think it would be more like lack of air, considering it will run at 3-4k. Set those, then post back.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
