Got TPI Commander 950, some ?'s
Old Jun 8, 2003 | 01:33 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Well the motor is sitting on the stand, im busy painting up the plenum and intake and porting and all that good stuff.
Having problems finding 14MM - 3/8 NTP fitting, and 14MM - 8AN fittings for the fuel plumbing. anyone have ideas there?
The motor is sitting on a stand, im guessing i should install the TPI and the harness and sensors while its out of the car right? any forseeable problems there?
As for the ECM, when i pull out the 305 TBI i should remove the factory harness right? any benefits to leaving it in there? its an 89, so do I need any wiring for my guages or VSS or whatever?
Im a bit confused about the converter lockup. the commander cant control it, but is my ALDL paperclip lockup switch still goina work without the 305's old ECM? I have a feeling not.
I was thinking a HOBBS Switch, that sends 12V at a certain vacuum to my purple lockup wire. that way when i was on the highway or around town at over 10" or so, it would lockup. should work right?
Is my brake / converter un-lock switch still goina work without the ECM?
Im keeping the serpentine pullies and belt, but I dont know if ill need any special pullies for my pre-80's motor. the pullies are coming off the 305 89' TBI, can i just swap them over? I have perf. RPM heads, so i think the necesary holes are there...
Also will my factory 305 TBI distributor work with this new TPI harness i have? Same thing for CC timing?
Ive got more but thats it for now!
Old Jul 7, 2003 | 11:20 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Right! anyways uh...
the motor is in, and im beginning the wiring process.
my main concern is the ignition wiring right now.
My distributor has 2 plug holes, my coil has 2 plug holes.
I know one of those plug holes goes from coil to distrib.
that leaves a plug hole in the dist, and a plug hole in the coil.
one of them gets the plug from the commander 950.
where does the remaining plug go?
Old Jul 7, 2003 | 11:21 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
dp
Old Jul 8, 2003 | 08:25 PM
novakm's Avatar
one plug on coil goes to distributor. the other plug has 2 wirees. The thick one is the ignition (power) feed for the coil. the other is the tach output.
Old Jul 9, 2003 | 01:08 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
got it figured out, thanks.
Now my problem is with the transmission. I want to wire up a lockup switch, and i did some searching it appears i need to wire the tan wire to a switched ground. there are 5 wires coming out of the tranny however, i see the tan one, but what do the other 4 do? I know one has to be positive but which?
also the A/C compressor... thats just a simple 12V / G wire up right?
Old Jul 10, 2003 | 12:27 AM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Can't help, but quick question, what did the Commander 950 and harness set you back? And where did you get it?
Old Jul 10, 2003 | 09:32 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
From Summit for TPI engines the commander 950 is $820.
stalkier
Dec 6, 2015 11:25 PM
dyeager535
Aug 28, 2015 08:10 AM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
Sanjay
Aug 12, 2015 03:41 PM
