TPI Block Swap
Old Jun 11, 2003 | 03:57 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
TPI Block Swap
I have a 91' GTA w/LB9 and a 700R4. I just bought a early model 350 block, crank, rods, and pistons. I want to have it redone and stroked out to a 383. Will my TPI heads fit? I know ill have to have a chip burnded and etc. But my only concern is fitting. Thanks
Old Jun 11, 2003 | 05:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, heads will bolt on. But probably not the best choice for a 383.
Old Jun 12, 2003 | 12:09 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Why not a 383? What should i go with? And the block, im gonna say is in the late 70's.
Old Jun 12, 2003 | 01:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, I'm assuming you'll want to use the 305's heads? you currently have. The small chambers and valves would require some extra work ($-wise) to flow well for a stroker.
Best bet to get an idea would be to search for 383 and Heads, see what oithers use and how they perform.
You should also post your engine goals too..i/e 500hp/500ft/lbs require much more head than a 350hp/400ft/lb engine would.
Old Jun 12, 2003 | 05:06 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
So LB9 heads and L89 heads arent the same exact heads? Is there a specific way to see other peoples setups? With out haveing to look at everyones profiles?
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
lakeffect2
Aug 23, 2015 08:44 AM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
