broke bolt...Help!
Old Jun 12, 2003 | 02:04 PM
I RoC A Z's Avatar
Car: 1989 Camaro Iroc-Z
broke bolt...Help!
Ok I had to replace the water pump on my iroc....but I broke one of the bolts in the block....it is exposed about 1/4 in or so outside of the hole....what is the best way to get this thing out?
Old Jun 12, 2003 | 02:59 PM
ULTM8Z's Avatar
Uh oh. Sounds like the bolt simply siezed up in the hole. They do sell bolt extractor kits for broken bolts, but I'm not sure it'll work on a siezed up bolt.
You might have to carefully drill it out- inching up from a small size to one that is just under the minor diameter of the bolt hole. Then clean out the remaining pieces and debris with a good thread chaser.
Old Jun 12, 2003 | 03:29 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
If you snapped it off putting it in, you should be able to just grab it with vice grips and back it out. If it snapped off while trying to remove the bolt, then it's most likely rusted into the block and needs to be removed by the drill out, thread chaser method Pro-tour mentioned. Good luck man!
Old Jun 12, 2003 | 08:53 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i would try vice grips since you say it's a 1/4 inch out.... just rough up the surface so you can grab on and try screwing it out slowly
Old Jun 12, 2003 | 10:53 PM
I RoC A Z's Avatar
There is no room for vice grips lol. I broke it putting it back in. I just drilled a small hole in the center now i got to get a easy out....hopefully that will work. any other suggestions?
Old Jun 12, 2003 | 11:35 PM
I RoC A Z's Avatar
my dad got it with vice grips dads our the best :-)
Old Jun 13, 2003 | 09:52 AM
Vader's Avatar
Just remember that in a few days...
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
