A Few Plenum Port N Polish ?s
Old Jun 13, 2003 | 09:54 PM
Kevs87Z28's Avatar
Car: Yellow/Black 1987 Z28
Engine: 355 Carb
I have bought dremel that goes 35,000 rpm, mothers mag and aluminum polish, 120 grit dremel sanding bands, dremel high speed cutter i think its part # is 115, and a few things of different grit sandpaper.
what else do i need to port and polish, and what does wet sanding mean?
Old Jun 15, 2003 | 03:02 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
This is way easier to do than most people think. Just pull your plenum off and you can see for yourself what needs to be grinded down to improve airflow. Just don't get too carried away as you could accidentally go all the way through a wall.
I don't know why you bought polish though. A flap sanding wheel will do all the polishing you need inside the plenum after you've grinded it down with the grinder bit.
There's already more than enough info on this topic if you just do a search...
Old Jun 15, 2003 | 11:14 AM
bigals87z28's Avatar
Car: Check The Sig
hey ill help ya out... i got a 87 Z... theres not many of them out there, so why not huh! The EGR walls right after the tb needs to be taken down. Get a bit for the dremmel, it looks like a small tin can with fins around the side... i wish i had a pic.. ill take one before the day is out, but will have to wait to get developed. I did 80-100-120-220-400-660wet-Mothers mag and alum and it came out good. The polish is a cloudy and i want to get that out, but i think i need to use some compounds, but i really just like the look now. i might put it on tonight and test it out! ill let everyone know later how it turned out.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Reid Fleming
Oct 10, 2015 09:56 PM
