Is this a good cam?
Old Jun 15, 2003 | 11:12 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Is this a good cam?
Is this a good cam for my setup? I have no clue what Im looking for in a cam......I guess I could call COMP and ask them what they suggest..
i looking for a cam with some ummph!!! to go with what I have already done to my car...m in the process of getting headers so take that into consideration......
thanks
Cam Specs:
Lift int. 482 ex. 496
Dur. @ .050 int. 214 ex. 220
Lobe sep. angle 112 degrees
Old Jun 16, 2003 | 09:49 PM
ULTM8Z's Avatar
In my opinion, 214° on the intake borderline excessive for an otherwise stock 305. The headers will help, but keep in mind that a ZZ4 350 cid engine makes nearly 360 hp (over one hp per cubic inch) with only 208° intake duration. You don't need a wild cam (relatively speaking) to get good power. For a good streetworthy 305, I'd limit it to less than 210°.
The production 1996 LT4 Corvette cam, GM P/N 12551142, has 203°/210° and .476/.480 (with 1.6 rocker arms) and it was making 330 hp. You might want to look into that one. Or the ZZ4 cam itself with 208°/221°, .474/.510. These may not seem like big performance cams, but lift and duration are not the only story to tell. There's a lot to be said about the overall profile of the lobe, something which is not easily explained or understood (at least by me).
Some people may think I'm too conservative, but I figure, hey if I'm going to pull the engine and front end of the car apart to change a cam, I'm going to make sure that I don't go overboard and want to change it later.
Later on, some good mods would be to get a set of Vortec heads and the Vortec TPI baseplate from Scoggins Dickey. But check your smog laws first!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
