TPI questions
Old Jun 16, 2003 | 09:52 AM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
TPI questions
I'm looking into converting to TPI and I was wondering what would be the best for a street car.
- MAF or SD?
- Cold start injector or no cold start injector?
- What are all the things required to put it in
- and what on earth is a reasonable price to pay for a used complete setup
I have an '87 LG4/auto setup right now.
Old Jun 16, 2003 | 11:33 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Whichever setup you come across...use. Probably easier to find a MAF setup, since many more were made.
Only drawback I see for swapping, is the MAF is an expensive part to replace if it dies...plus there's a little more clutter under the hood for the additional MAF relays.
I'd run with/out the CS Injector, use an '89 EPROM if you wind up with MAF...you may have to have the VATs disabled as well.
What you want to look for is a complete setup...all sensors, wiring, ECM, etc...no use having to track it all down later.
Check the classifieds, asking prices range from 300-500.
Old Jun 16, 2003 | 11:37 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Take my stuff.
runners
base
plenum
TB
19#inj.
rails
Holley AFPR ($80 by itself new)
take it all for $50.
Old Jun 16, 2003 | 11:40 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
What year is your setup? I'm looking for a 89-92 plenum...but would take it all if needed.
Old Jun 16, 2003 | 12:42 PM
Spdfrk1990's Avatar
what is the difference in the tpi intakes through the yrs
Old Jun 16, 2003 | 05:28 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Would I need new throttle cables and fuel lines?
Old Jun 16, 2003 | 05:29 PM
Spdfrk1990's Avatar
a new throttle cable u would
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
