my plans. Any suggestions?
Old Jun 17, 2003 | 03:27 PM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
Ok, first of all, im currently running a 355 with edelbrock intake and carb, regular old manifolds, 700R4 with a good shift kit, and 3:73's.
I am planning on going to TPI, porting and polishing the heads and the TPI unit, also, the TPI will have a 58mm BBK throttle body. and i will be putting 4:10's in the rear. Are those to low for TPI, or would they be alright if the TPI is well ported with the stated throttle body.
i just want any coments and/or suggestions. thanx in advance
Old Jun 17, 2003 | 04:24 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
I have called many companies with the same questions you have. a 58mm throttle body is too much for a 350, it will slow air velocity and hurt your power output. also 4.10 gears are way too low for tpi because it cant rev high enough to take advantage of the gear. i have 3.42s and my buddy has 4.10s. our motors are both tpi 350s and are setup pretty much the same. about midway through the 1/8 mile i will walk right by him like he is sitting there. i would say youll be much happier with a 52mm throttle body and 3.42-3.73 gear to take advantage of the awesome midrange that tpi delivers. if you want more revs with a lower gear, youll need something like a miniram.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
