Need input on planned mods
Old Jun 19, 2003 | 06:58 PM
87IrocConvert's Avatar
My Iroc is a 1987 Convertible with a 305 TPI 5 speed. It is a rare car and I want to keep it looking as stock as possible.
I am looking for more over all power without affecting my driveability, emissions, and/or gas milage.
I have a set of Edelbrock headers, hi-flow cat, and an Edelbrock cat-back exhaust.
I have a set of 1989 Aluminum Corvette heads that I am planning on sending to TPIS to have them ported and everthing else they do to the heads.
I was thinking of replacing my 305 injectors with a set of injectors off of the same corvette.
I have ported the plenum and I am thinking of getting some bigger runners like accel or something similular that looks stock.
My camaro came with the better cam (or so I've read) since it has a 5 speed. Would I benefit from going to a 1.6 rocker arm? Can I use a roller rocker with my engine?
Would I need to do something with the computer?
Would I benefit from a 52mm throttle body if I do all the above mods?
Any other small improvements or mods would be very helpful.
Thanks guys
Old Jun 19, 2003 | 07:09 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
hey,
i would go for the bigger throttlebody, and some slp runners.
some other ideas that'll keep it lookn stock but give you some extra oomphh!:
underdrive pulley set
gutted airboxes with some k&n filters
free ram air mod
different gears
lt1 hotcam
ported intake manifold (or a high perfomance manifold)
smog delete if you don't need emissions...
and yes, the roller rockers will fit.
and there is lots of other things i can't think of.
Old Jun 20, 2003 | 07:31 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Spend your money on the intake base first, especially since you will have a good set of heads to put on.
Old Jun 20, 2003 | 02:32 PM
I am having the intake manifold ported. I am also planning on the underdrive pulleys, Adj. fuel regulator, K&N air filters, I have cut the air box, and eventually some AS&M runners.
I need to know should I get self aligning or non self aligning roller rockers? Which came in the 89 Corvette heads? What is the difference?
Old Jun 20, 2003 | 05:09 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Guides plates and price are going to be your only difference between self-alligning and non.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
