car runs with ignition off....NOT dieseling!
Old Jun 21, 2003 | 05:25 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
I can turn the key off on my T/A and the engine continues to run.....it's not desieling for a few seconds......it keeps running! When the key is turned off, the RPMs drop a bit, but turn the key to the 'on' position and they jump back up.
Old Jun 21, 2003 | 07:22 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Ignition switch....
Old Jun 21, 2003 | 09:20 PM
Engine: LB9/383
If I remove the fuel pump fuse from the holder (the one under the hood, near the battery) the ignition switch works normal. Everything comes on and off with the key.
Old Jun 22, 2003 | 12:51 AM
Engine: LS3
Transmission: 6L80E
Ummm...yeah, but part of the ignition switch is still bad...that is my 1st guess....
Look at the ignition switch...and see how many contacts are impacted by the switch...see what I mean?
HTH,
Old Jun 22, 2003 | 02:58 AM
Lunkan's Avatar
Car: Pontiac Turbo TransAm
Engine: Buick 3.8L
Transmission: TH400 Switch Pitch
Are You using MSD-box? I saw on their page, that this could happen some times.
Old Jun 22, 2003 | 08:29 AM
Engine: LB9/383
I'm really trying to narrow it down before I decide to change the ignition switch. It's not a fun job at all!
I don't have an MSD box (installed )
Old Jun 22, 2003 | 08:40 AM
Engine: LB9/383
oh, ignition switch. I had it confused with the cylinder. Never mind. I'll check it out and see whats up. Thanx.
Any other ideas?
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
