how to remove fuel rail?
Old Jun 22, 2003 | 04:33 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ive got the 4 bolts off the top and I can wiggle the whole unit but the injectors and fuel rail wont come off...am I not doing something right? Do I just pull real hard and they should pop out of the O-ring thats in the intake? Im scared of breaking the injector to rail connection....
thanks guys..
Old Jun 22, 2003 | 04:42 PM
Z_Ghost's Avatar
I had that problem the first time I pulled my injectors out, they were stuck in the intake and you have to pry them out. If you work one side at a time and as they start to come out go to the other side eventually they will come out.
Just make sure that the fuel lines are disconnected.
Old Jun 22, 2003 | 07:16 PM
I got them out..they were just really in as you said...
thanks Z
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
3rdgenparts
Aug 8, 2015 07:09 PM
92projectcamaro
Aug 6, 2015 01:20 PM
