fuel pump took a crap again
Old Jun 26, 2003 | 12:50 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
well this is the third fuel pump in 6 months. All of them were oem fuel pumps, soi m gonna upgrade with a high performance. I was searching through the forums and saw that the walbro 255/lp in tank fuel pump will work good on my car but i just wanted to ask u guys which fuel pump will be good. Plus i'll be buying a afpr with a gauge.
Old Jun 26, 2003 | 01:16 AM
BORLAZ06's Avatar
man that sucks. u should check and see whats causing the fuel pumps to go bad.
the walbro 255 is a good pump. ive noticed a slight drop in gas milage with it. you might notice a slight drop in gas milage too oh wait...ur gettn a AFPR, good idea
Old Jun 26, 2003 | 02:31 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
well with my original fuel pump, it started to suck in air so i replaced it with a factory oem fuel pump. The next day the new fuel pump started to suck in air also and then it started to stutter and stalls out. Got that replace with another factory fuel pump and also a fuel filter cuz it was clogged. So after a couple of days with no problems with my current fuel pump it started to to shien again, but this time i said forget it i let it run with the problem. After couple of days, it went away and now i hear it again 5 months later. I'm hoping that this walbro 255/lp will be enough to push a ho 350 or a 383 that i might be considering. Btw my gas milage been screwed up since i took the car for a complete tune up. now i do like 200 miles till empty and thats jsut driving normal with mix highway and streets.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
