MAX effort 350 TPI
Old Jun 22, 2003 | 09:01 PM
Tranny Man's Avatar
MAX effort 350 TPI
How far can the stock TPI go? I'm getting a new harness made to convert my MAF to SD and I'm working with a good friend of mine to start burning our own chips. I have SEVERAL motors I can put this intake on to. I have a 327 350 and a 383. All of these motors are shortblocks. So I will need a cam no matter what route I go. As for heads I have 441's 882's 624's the exhaust will also be a limiting factor I can only fit block hugger style I will be running a lock-up 700 with a 2000 stall converter. The intake is totally STOCK. I dont want to have to buy a new TB or runners I'm just looking to see what you guys have gotten from a TPI in stock form. ALSO emmisions are NOT a problem and the fuel system is good to 1000 hp. Keith
Old Jun 23, 2003 | 12:40 AM
Morley's Avatar
Re: MAX effort 350 TPI
Originally posted by Tranny Man
How far can the stock TPI go? I have a 327 350 and a 383. All of these motors are shortblocks. So I will need a cam no matter what route I go.
Well for starters, your fuel system is good for way more than twice what you'll get from a stock TPI.
Forget the 327, it turns high RPM, the TPI doesn't.
I'd go with the 383, accel manifold and SLP runners, no need for an aftermarket TB, the stock one will flow plenty.
The intake ports on the stock manifold are just too small for high HP then the runners will be the next thing that restricts.
Stock setup with a N/A engine, I'd say around 400 HP at the flywheel. The engine will need to breathe to go into big numbers.
Old Jun 23, 2003 | 07:35 PM
Tranny Man's Avatar
Im sorry I need to work on being more clear. What I'm asking is if you had a STOCK intake either SD or MAF what sort of short block yould you build? the chip is unlimited but I cant put any more money into the induction system I can however get new injectors Keith
Old Jun 24, 2003 | 08:49 PM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
howdy i had a 383 stroker with a stock 305 tpi intake, trickflow twisted wedge heads, stock rocker arms, custom grind cam 212/218 dur. @.50 .44/.464 lift, 112ls. msd6al, 3.73, stock suspension. i never found out the horsepower nbrs but i did run a best of 13.2 @103.5mph in the quartermile car weighed 3530 with me in it and it was done on street tires. u mentioned needing a cam. i am selling the cam mentioned above and also the 22lb aftermarket injectors with the chip that was burnt for this combo if u are interested? let me know email me at daxnutt@hotmail.com thanks!
Old Jun 26, 2003 | 02:18 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Go with the 350. The 383 is a waste for a stock TPI.
You'll have larger cubes down there, but no way to feed it through the stock base and runners.
Spend the $100 and atleast have the base ported. That's what I'm doing while I have the base off when I put my new Pro Topline heads on. The base is THE most restrictive part, followed closely by the runners.
Old Jun 26, 2003 | 03:49 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
IMO, get the plenum ported, LTR's at least, and a TPIS BM base, leave the TB. Do it right the 1st time and forget about it being stock when it has more potential modded since it's a little restrictive from the factory. Go with at least the 350. The 383 will make HIGH TQ with TPI.
Old Jun 26, 2003 | 04:38 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Wow - everyone suggested aftermarket TPI parts. I would too, but you asked about stock. Do the 350. The 327 winds too high, the 383 wants to much air. The 350 is ideal, chevy used them huh?
Anyway, use a cam similar to the one mentioned (or buy it, he pitched a sale)... relatively low lift, and long duration is what the TPI will work best with. If you select the heads and cam carefully, I think you can grab 12.99... tho that low stall TC won't help
Old Jun 26, 2003 | 05:03 AM
Tranny Man's Avatar
The only reason I'm looking towards a stock induction set up is because I'm just about out of money!! the motor in my 3rd gen is about to die and I use it for work. I have the 383 short block but it can't finish the heads just yet. I want to put the motor in a truck when the 383 is ready to be installed in the camaro. I dont want to spend a lot of money on the truck motor when the 383 still needs a great set of heads. Keith PS I e-mailed him about the cam and injectors waiting for a reply. Keith
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
