tpi c1500
Old Jun 26, 2003 | 08:19 AM
flamenchevy's Avatar
tpi c1500
I am getting ready to put tpi on my 89 chevy 1/2 ton truck. I will be using my stock short block for know. what cam would be good for a truck? I will be using pro lightning heads. Probably 180cc. I will get an aftermarket manifold and runners ( any recomendations). I have a 700r4 tranny and a 3.42 rearend. any help would be great.
Old Jun 29, 2003 | 10:21 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I can't help much, but I can tell you that I'm doing some similar stuff to my truck.
I put some heads on and that alone helped a bunch.
I'm getting a cam this wk. I think. I lucked out and found a complete roller setup on ebay.
I decided not to put a lot of cam into mine cause I use it as a work truck and under normal use I don't get much above 2100 rpm except on entrance ramps or for passing.
The cam I'll be using will be about 202 in/ 208ex @.050.
I'm going to add a TPI later, I'm sure it will work great!
A stock TPI might be a good idea, you'll save some $$ that way.
I'm assuming that yours is a 350.
Best of luck!
Old Jun 30, 2003 | 03:16 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Really depends on what you are going to use it for. If for a traditional work like truck then a duration as mention would be good. Since you are going after market runners guess you want a little more umph. Summit sells a nice cam for cheap that might be right up your alley:
http://store.summitracing.com/partde...rt=SUM%2DK1103
214/224 duration at .005.
Old Jun 30, 2003 | 07:59 AM
bigals87z28's Avatar
Car: Check The Sig
the ZZ4 cam or ZZ409($$$) are good cams. the zz4 is cheap for a roller cam, and the 409 can be VERY expensive, but gives you good power. i got my zz4 for 120 shipped to me. Not bad when most roller cams are in the 200+ range. also, look to get a tad bit bigger TC to really take hold of that power.
Old Jul 1, 2003 | 02:22 PM
1slow60's Avatar
Just curious but how are you planning on making the computer work with the truck? I have a complete TPI set up I was thinking on putting in my 89 350 4x4 till I found out that the computer was controlling the cruise control etc. Are you planning on totally rewiring the truck using camaro parts? I am really interested in this swap myself. Keep us up on what happens.
Old Jul 1, 2003 | 03:10 PM
Car: '85 IROC
Engine: LB9
I put a carb on mine, cause I had a fire and part of the harness was burned. I plan on getting a TPI soon but for now, on my '88 the cruise is working and there is no ECM at all.
Old Jul 3, 2003 | 09:32 AM
Thanks for the help. It is a 350 and I do want some more ump. I am thinking maybe 350 hp.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
