Next upgrade?
Old Jun 28, 2003 | 09:55 AM
leirch's Avatar
Next upgrade?
Guys,
I debating on what to do with the car next.
Its an 87 tpi, converted to the 730ecm.
Engine:
383ci
LPE219 cam
AFR 195's
Miniram
crane 1.6's(wanting to upgrade to some nice steel ones, these are getting noisey)
trick-flo hardened pushrods
Transmission:
200r4
more or less stock from a GN
stock GN torque convertor
11x24 aftermarket 200r4 transmission cooler
Differential:
10bolt, 7.5 rear disc(from a 94Z)
3.73's
rear girdle
Suspension:
Weld in Sub-frame connectors
Hotchkis LCA's
What would you guys suggest be the next upgrade?
I was really wanting to do a turbo, custom fab some headers, and swap the the 749 ecm. I haven't really decided. That is a big step though. May go another year NA and then go turbo.
Assumming I stay NA, I was thinking a 3000stall and maybe a 230/230 or 236/236 cam.
Maybe some suspension upgrade? Ideas?
Old Jun 29, 2003 | 01:55 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
How about some slicks? Orsome custom prom burning... there is alot of potential locked up in that stock ECM.
Old Jun 29, 2003 | 03:11 AM
leirch's Avatar
Yes, slicks are a must... I'm prolonging the purchase in fear of nuking the 10bolt
I'm doing the custom tuning... it runs like a stock 350 until you get ugly with it, just seems that the combo isn't exactly matched yet.
It comes alive at 3200+ rpm(granted it pulls from 2500+)
Old Jun 29, 2003 | 09:53 AM
86 IROC's Avatar
Camshaft seems a bit tame, try a ZZX or a CC306, definately could use a little more converter. You didn't mention your exhaust system - what does it consist of?
Old Jun 29, 2003 | 10:04 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
seems like you already know what needs to be done.... sort out the probs with the current combo, and upgrade the rear ( 9"???)
Old Jun 29, 2003 | 10:29 AM
leirch's Avatar
I'm running SLP 1 3/4 with a Borla 3in cat back.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 25, 2015 04:56 PM
