What is this?
Old Jul 1, 2003 | 12:35 PM
magn2o's Avatar
What is this?
I know this will be hard to describe without a picture (I'll try to get one later).. but there's a cable that runs from the side of the throttle body to an area down by the driver's headlight. It's connected to a flat plate with various adjustment holes in it. You need to remove a metal clip, then you can adjust it to whichever hole you like.
It all started with me trying to adjust my TV cable, and I wound up screwing with that. I adjusted it and took up the excess slack in it, now it's tight and firm. Haven't noticed a difference with anything, however. I was just curious as to what it was.
Like I said, I'll try to get a picture later if no one has a clue what I'm talking about.
Old Jul 1, 2003 | 02:37 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Sounds like the connector for cruise control.
: shrug :
-Schultzy
Old Jul 1, 2003 | 02:50 PM
magn2o's Avatar
: shrug :
-Schultzy
But would the cruise control have a slack adjustment setting?
Old Jul 1, 2003 | 02:55 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
get a picture
Old Jul 1, 2003 | 04:25 PM
magn2o's Avatar
Originally posted by N8MAN1068
get a picture
Workin' on it.
Old Jul 1, 2003 | 04:35 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
i agree with others cruise control adjustment.
