question about carb to tpi swap and cams
Old Jul 5, 2003 | 07:46 PM
lucassays's Avatar
i have a bone stock 84 z28 305 ho. im going to swap on a 91 tpi setup. im wondering if my cams are better or worse then the cams that came on stock 305 tpi engines.
Old Jul 6, 2003 | 11:05 PM
airdeano's Avatar
its not the "bomb" to have, but itll get you by...
if your looking to do it the same time as the TPI swap.. call a cam manufacturer
for specs. gary anderson @ comp its well suited to answer your questions.
to simplify the swap, do the cam change later as you dont need another
issue complicating your swap. over tightened valves, wrong cam
timing, etc...
airdeano
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
